GAYLON'S WEB SITE
Date:  9-14-2013
Number of Hours:  3.00
Manual Reference:  Brakes
Brief Description:  Bonaco Fuel Lines – Tunnel
Sept 14th, 2013, 3 hours.
I received custom fuel lines from Bonaco that I specifically order to match the fuel system layout in the tunnel and under the seats. The fuel lines are made with PTFE inner hose, outer stainless shielding with a plastic outer shielding and -6 connections. All measurements where spot on for the layout of the system. All connections torqued and marked with yellow torque seal.
