Brief Description: Section 38, Rudder Pedal after Market Brake Lines
I purchased the Bonaco brake lines for the after market Control Approach system. The Bonaco lines fit well and function with the movement of the pedals well. Spent 1 hour fitting them on December 15th. QTY 2: -3 Hose assy w/clear at 37” OVL -3 straight to -3 straight @ $ 20.95 ea QTY 3: -3 Hose assy w/clear at 12” OVL -3 straight to -3 straight @ $16.56 QTY 1: -3 Hose assy w/clear at 12” OVL -3 straight to -3 90 degree @ $22.50 QTY 2: -3 Hose assy w/clear at 31.5” OVL -3 (with -4 Nuts each end) straight to -3 straight. This is for the gear legs from belly to caliper. @ $28.50 each QTY 1: 826-3D, for replacing stock plastic “T” @ $7.70 QTY 8: 822-3D, 1/8 NPT to -3 male 90 @ $5.00 $40
