On Friday May 5th, I received my Control Approach rudder pedal system. I spent about 5-6 hours assembling the system. Other than a couple of bushings not being the correct sizes, mostly had to file or grind to the appropriate size, everything went together very well. It’s a great looking system and I can’t wait to install it into the fuselage. I still need to cut the center tunnel top for the rudder pedal control arms to fit inside and mount the hydraulic brake cylinders to the system as well. Paul from ControlApproach made a great system!
