Harness termination begins. I started with connecting the VPX Pro to various connections coming from the harness. I decided to not connect the CO monitor to the GEA24 Discrete In 2 J244-42. I choose to not connect this since I have a dedicated yellow LED in the panel. I disconnected the Trim, Aileron and Flap Position sensor wiring form the GEA24 unit. The VPX Pro is sending the Trim, Aileron and Flap Position sensor status to the MFD via RS232. I removed the Main Bus Volts wiring J244-25 and Main Amps J244-36/37 to allow the VPX Pro to provide this information to the MFD.
