Some work has been done on the left wing for installing the Gretz pitot tube mast and supporting structure. I have added a little more support than the Gretz instructions call out. I have also worked on mounting a Red Tip VHF antenna under the wing. This is slightly abnormal from most RV10s but this is being done because we plan on using a MotoPod for hauling larger items that won’t commonly fit in the cabin.
