Fuel Tank Sealant – was the topic of the day. Started attaching the VA-141 Finger Strainer Flange, T-1010 Anti-Rotation Plate and nut plates along with various small plates used for sealing the holes in the end ribs used for holding formblocks in proper alignment during hydropress forming of the ribs. Ever piece attached needed too have the fuel tank sealant applied between the parts and the riveted in place. The T-1011 Stiffeners and VA-112 Drain Flange were also riveted onto the wing tank skins with the fuel tank sealant between the pieces.
