Dana and I spent a short amount of time dimpling the outboard leading edge, left and right. Two people make the job much faster. Also dimpled the #8 screw holes in the left and right splice strips.
I worked with the outboard leading edge and fuel tank skins left and right in a bath of Alodine. I was able to get the conversion to work fairly well on the fuel tanks but not so well on the outboard leading edges. This will be fine since I will likely prime the outboard leading edge left and right. I mostly wanted to complete the process with the fuel tank skins and I did. No pictures
