GAYLON'S WEB SITE
Date:  7-25-2011
Number of Hours:  3.00
Manual Reference:  Section 16
Brief Description:  Top Wing Skins
Section 16 has the top aft wing skins laid out so you can final drill #40 most all the holes. I needed to finish installing the wire route tubing and to make things easier I need a more rigid structure to work with, hence the addition of the top skins. I cleco the wing skins and wing walk doubler and j-box stiffeners in place then started routing the wiring runs. I am now stuck with a small dilemma since the hose mounting clamp that I wanted to use is rather large and could possible interfere with how you drive the rivets on the lower skin. A little research is needed before I proceed.
Picture of empty bad of hose mounting tabs
wire runs
wire runs
