GAYLON'S WEB SITE
Date: 7-17-2011
Number of Hours: 5.00
Manual Reference: Section 14-4
Brief Description: System Penetrations in Wing Ribs
Section 14-4, drilled holes in wing ribs for the vartious electrical wires. Pitot tube, pitot heater, AOA air hoses, 1 VHF, Duck Works Light, Wing Tip Lights,Strobe, Tie down Light, Auto Pilot, Fuel Guage, Stall Waring and Aelron Trim.
The #1 wing rib will have a connection bulk head installed capturing most all the wires. The most aft hole is for the strobe wire. The large 3/4" hole is for Vans tubing. The hole located above that is for the VHF antenna that will be installed in the wings underside.
Left Wing, #13
Left Wing, #1
Left Wing, # 1-5
