Brief Description: Elevator push rod adj, HS Elevator stop/doubler ad
Adjusted elevator pushrod using an aluminum template made to the specified 91.4 degrees. Moved on to the elevator stop adjustments. F-1011B and F-1012D stop doublers did need to be filed down to allow the 25 and 30 degree angles. The left HS Elevator required that F-1011B be filed to reach 25 degree, it was only off by 2 degree. The right HS Elevator required F-1012D be filed to obtain 30 degrees, it also only needed about 3 degrees.
