Brief Description: F-1010A,B and F-1014 then F-1011D and F-1012D
Finished drilling the 1074 and 1075 skins common with the frames and longerons. Verified the 1010A and B where still centered, adjust little bit then drilled. Drilled all the F1014 holes. Previously I had made the F-1011D and F-1012D now was finally time to use it! Put them in place a drilled the required holes.
