Started out the evening by applying the tank sealant to the elevator foam ribs, placed them inside the elevator trailing edge then put sealant on the AEX trailing edges and clecod them into place on the elevators. Set the elevators on the bench and applied pressure to the edges to create a good bond for the tank sealant and surfaces. I will let this cure for a couple of days.
I moved on too completing the Trim Tabs, I riveted the E-918 and E-1018 Trim Tab Horns to the skins. Then riveted the E-920 Trim Tab Spar. Applied tank sealant to the Trim Tab Ribs, placed them into position. Placed the Trim Tab assembly into the trim tab cradles and clecod the top skin of the Trim Tab to the Trim Tab Spar. Installed blind rivets in the edges of the Trim Tabs. The Trim Tabs will sit for a couple of days.
