Started on Elevators by separating the E-1008 Elevator Ribs into individual parts, deburring the edges then clecoing them together with the rib halves final drilled #30 hole. Made the E-903 Outboard and E-904 Inboard Tip ribs 90 degrees, straightened the E-904 and E-903 Tip Ribs by fluting between the pre-punched holes. Assembled two Tip Rib Assemblies by clecoing together the E-903 and E-904 Tip Ribs and the E-913 Counterbalance Skins.
Trimmed the E-1022 Shear Clips and final drilled #30 short flange holes.
Note: the Tip Rib Assemblies are very tight fitting, and as noted per plans a couple of the 8 holes that are not to be final drilled do not line up, this will be dealt with later.
