GAYLON'S WEB SITE
Date:  10-4-2007
Number of Hours:  4.00
Manual Reference:  Section 10-8
Brief Description:  Left side skin, F-1011, F-1012A,B
I started working with the F-1011 Bulkhead trying to fit it into location. Because of the tight radius bend on the tail cone section the pre-punched tabs sis not conform to the tail cone curve as nicely as did the front frames and bulkhead. I had to modify the tabs on the F-1011 just as I did on the vertical stabilizer so the tabs would not create a "dent" punching out of the tail cone skin. Lots of time was spent on this step to ensure a nice fit with no gap between the mounting pieces. I will try to get pictures later of it... forgot to get em. I then moved onto placing the F-1012A, B into place and just like the F-1011 it also need its tabs trimmed to fit the curve of the tail cone. After lots of time spent on these pieces I started to Cleco the Left skin into place. Has to order more clecos, ran out of them!
