GAYLON'S WEB SITE
Date:  3-27-2008
Number of Hours:  1.30
Manual Reference:  Secion 11-8
Brief Description:  Rework F-1095G brackets
Decided to rework Trim Cable Anchor Brackets since previous owner who I bought the kit from had completed the parts but with poor technique (rivet work and drill hole work). Also I did not see why the trim anchor brackets (according to Section 11-8, Figure 4) had to be stagger mounted. The basic problem I see with the system, according to plans, is that one cable will always continue to travel as the trim actuator is operated after the second cable has stopped movement,, based upon the point of attachment F-1095B. I created one bracket to hold both cables and will attach the cable ends to one common attach point on the F-1095B. This will enable both cables the same amount of travel and make for a much easier adjustment.
