GAYLON'S WEB SITE
Date:  6-26-2007
Number of Hours:  3.00
Manual Reference:  Section 8-11
Brief Description:  Started final assemble of parts
Riveted the front spar and HS-1004 ribs, HS-904 ribs together leaving the two outer most ribs out. Rivet front spar to skins, but realized two of the HS-1004 ribs where not in the proper location (switched from original position when matched drilled). Removed those two ribs and re-installed them with a much better fit.
removed HS-1004 ribs
re-installing HS-1004 ribs
