Worked with the Trim Cable Anchor Brackets to discover if I could "re-use" the existing E-616 plates with the new Anchor Brackets I made. Result: nope, have to order two new E-616 plates. The prior existing holes cannot be "filled/plugged" with filler rivets because of the new Anchor Brackets design. Also I am checking on the distance from front of nut to bottom of cable cutout hole for trim cable, I think there will be interference in this area. This will allow for me to modify the position of the Anchor bracket o the next plates.
