Brief Description: Starting to mount elevator to HS
Installed the threaded eyebolts with some anti-seize on the threads to the recommended height. Installed the elevator on to the HS and measured for the 1/8" clearance signifying the elevator is true to the HS. Had to adjust the eyebolts a couple times to get the 1/8" Good clearence and motion on both elevators according to the manual.
