Worked with installing the F-1006 an F-1028 after I realized the bell rank ribs where in place backwards. Moved onto the longerons, this required making F-1010B and placing it with double-sided sticky tape to F-1010A, then placing F-1014 and F-1011B on top of that. The longerons where put into place and verified to be in place then clamped. Started to drill the right side longerons with making sure the longerons and skins meet at the correct apex. The right side longerons are drilled.
