Brief Description: Add R-1014 weight to the rudder
Installed the R-1014 weight. This was a straightforward process. I did not need to install the optional third bolt in the middle of the weight to keep the skins from ballooning. The skins lay perfectly flat after they where tightened. I used Napa 7220 self-etching primer between the skins of the over lapping joints.
