Brief Description: Roll Leading edge of Rudder, install R-1014 weight
Rolled leading edge of rudder with the help from a friend Daniel. I used a 1" diameter pipe that resulted in a good bend requiring a very small amount of messaging to get the skins to lie correctly. I then put a slight bend in the overlapping skin to help make a tight overlap joint of the skins. Also used Napa 7220 self-ecthing primer between the skins for added protection.
