Brief Description: Rivet Trailing Edges, drill Trim Tab Hinges
Started with the Trim Tab Anchor Brackets and rivet those to E-616 plates. Then started to rivet the trailing edge of Elevators. I used the same method as with the rudder trailing edge except I place all the rivets in from the top skin and bucked the bottom side. This allowed a cleaner appearance on the top skins. The trailing edge results where nice and straight. I then moved to cutting and drilling the trim tab hinge material. The hinge was drilled and clecod to the Elevators and now I am working on drilling the Trim Tab hinge side.
