GAYLON'S WEB SITE
RV-10
Section 9
Clean up and sanding
After painting, clean up time. Also used 150 grit sand paper to prep the portion of skins that will have the tank sealant and foam blocks attached to them.
Trim tabs
Trim tabs
RV-10 Home
1518
Avionics/Instruments
Avionics/Wire
Battery Box
Cabin Cover
Control Approach Rud
Doors
Elevators
Empennage Assembly
Fairings
Flightline AC System
Horizontal Stab
Lighting/Electrical
MotoPod
Oxygen System
Practice Kit
Service Bulletin
Shop
Tail Cone
Trim Actuators
Tunnel Battery and E
Vacation
Vertical Stabilizer
Wing Landing Lights
380
