GAYLON'S WEB SITE
Date:  7-22-2007
Number of Hours:  8.00
Manual Reference:  Section 9-17
Brief Description:  Bending Tabs and trim tab bottom skins
Started today with bending the E-919 and E-1019 (right side) Trim Tab Skins by using two of the wedges created from when I made the Trim Tab Blocks. This provided a nice clamping surface to hold the skins in place so they didn't move. Each tab was bent into position using a piece of wood and some elbow grease with a hammer. After that I final drilled all the #40 holes in the Trim Tabs. I dismantled the Trim Tabs so I could put a 15-degree bend in the lower portion of the Trim Tab skins. This will allow the Trim Tab to move freely without interference to the elevator. I then trimmed and attached the elevator horns made from E-918 and E-917 (E-1018 and E-1017 right side) parts to the trim tab elevators. And finally I then proceeded to dimple, debur the skins and parts.
Bending the tabs
Bending the tabs
All clecod togather
All clecod togather
Elevator and Trim Tab parts ready for Alumaprep, Alodine, and priming
