Brief Description: Debur, start elevator trim tabs
Still working on deburring all the parts. I started on the elevator trim tab since I hadn't primed all the parts yet for assembly. Jumped over to Section 9-16 and started making the elevator trim tab clamping blocks. Well luck would have it, I didn't have any wood to cut the blocks from so off to the store we go. I needed the Home Depot trip regardless since the metal cutting band saw blade decided to break while I was cutting the PVC foam ribs for the elevators. Also picked up more sanding supplies while I was there. Finally got all the plastic removed and the foam block locations taped off for paint and tank sealant that secures the foam ribs in place.
