Final drilled the holes common to inboard E-905 Web, E-1002 front spar, E1008 Ribs, trim doubler plates (E-615), E-1007 rear spar, E-1022 shear clips and attached the E-903 Outboard Tip Rib assembly. Also placed the E-921 Elevator Gusset to the E-905 Root Rib and the E-1007 Rear Spar and final drilled as well. Placed E-1001A Top Skin into place and Cleco. And finally placed the E-102E trailing edge wedge in place for marking. Then stopped for the night.
