Brief Description: Started final assemble of parts
Riveted the front spar and HS-1004 ribs, HS-904 ribs together leaving the two outer most ribs out. Rivet front spar to skins, but realized two of the HS-1004 ribs where not in the proper location (switched from original position when matched drilled). Removed those two ribs and re-installed them with a much better fit.
