GAYLON'S WEB SITE
Date:  11-7-2013
Number of Hours:  16.00
Manual Reference:  none
Brief Description:  Aerosport Panels Arrive
Not sure on the date of when the Aerosport panels arrived since I got rather busy with work and other things going on. My best guess is they arrived in early November.
Date Nov 7th, 2013, 16 hours
I spent much of my time beginning to understand what the task at hand was. I laid most of the components out in the panel. There were several holes and tolerances that were either wrong size (too small). Some of the holes being smaller actual was ok since I hadn’t determined the final LED signal light I wanted to use yet until I saw it on the panel. One of the dimmer control knobs is rather close to the Left PFD but this is likely a non issue.
I continued with understanding how to mount the avionics trays. This took a bit of effort to get them correctly aligned where I wanted them. I used various support behind the panel to anchor the trays to each other and to the sub panels. I believe I have captured enough attach point to secure the trays and the weight they will be holding.
