Brief Description: Installed the ELT – ACK Technologies
Sept 29th, 2013. 8 hours
Installed the ACK Technologies ELT under the vertical stabilizer where many other RV10 builders have placed it. Created 4 stand offs so the ELT could be raised to fit into the given spot. I routed the 4 pin telephone cable to the front panel and mounted the ELT antenna. I have yet to route the GPS signal wire to the ELT since that is part of the Avionics harness that is not installed yet.
