Brief Description: Center Console Mountain High Oxygen System air con
Aug 31, 2013. 6 hours The 4 oxygen control pulse units from Mountain High Oxygen will be mounted in the center console since this provided the most logical location for the units versus work required for other locations. The hose routing went from behind the rear baggage bulkhead to the flap control tube then over to the center tunnel. I temporarily placed the tubing and several cable tie mounting brackets since I will later come back and run the communication wire for the units. I also ran black tubing inside the tunnel to accommodate the wire run up to the dash where the control head will be mounted. This tube will also house all the headset jacks along with music audio input jack for the rear seats.
