8/25/2013, 2 hours I worked on mounting the throttle quad to the attach bracket provided in the kit from Aerosport. I requested the throttle quad mount that is attached lower than the standard mounting kit since I wanted the angle and height of the throttle controls to be lower. I like the feel of it better than of the standard mounting method plus this allows for better access to the fuel selector valve. I was able to get all the mounting attach brackets drilled and nut plates attached. Now I need to attach it to the center tunnel panel. I am waiting on the new carbon fiber quad insert piece since they need to make a special one since to make this work with the standard panel the piece needs to be cut slightly longer. It should arrive this Thursday.
