I started working on mounting the EDS-DP air distribution controllers, all 4 of them. I decided to mount the units in the Aerosport center arm rest console. The mounting was fairly straight forward except I needed to pay attention to clearances because of the mounting angled surfaces I was working with. Over all it turned out ok but I was slightly large on mounting hole cut out but a larger surface o-ring will help cover the very small gap that appears between the control module and console. I apparently only tool one picture but will later update the page with more of the locations where they are mounted.
