March 3rd, 2013 I continued working on the overhead panel. I will be mounting the Landing, Taxi, Strobe, Nav, and strobe wing/tail select switches in the overhead. I installed the front seats and overhead to verify the switches are accessible. While the switch labeling wont necessary be in front of you for easy viewing it will be easy to read and will be come muscle memory once you remember where the switches are and the order they are in.
I am using Front Panel Express to create and build the panel in. It will be black with white lettering. For some reason my printer decided to printout the scale panel in a shade of pink. Sure my wife would like that. I cut out the holes in the panel t verify switch placement and spacing. once everything was satisfactory to my likening I order the panel. Worked about 8 hours.
