March 2nd 2013 I spent the day working with the overhead attaching a couple of wire run conduits and wire tie down points. I epoxied all of those in place and then started to run the wires that would be installed in the overhead. Four Aveoflash led lights will be installed, two aft overhead the passengers and the other two will be over the front seats. I cut the mounting hole for the two rear lights but did not cut the front two holes since they will be mounted in the front aluminum panel that attaches to the overhead. I am waiting on a circle cutter from Aircraft Spruce.
I terminated the four wires that will be connected to the Aveaoflash led lights and ran two extra wires with connectors for the overhead led stripes that will mounted along the outside of the overhead once the interior gets installed. worked about 6 hours.
