December 27-28th, I continued to work on fitting the McMaster door seal to the door openings. I cut a piece of the seal and put epoxy mixture inside of it and pushed it into place. I allowed this to cure and then continued with the remaining portion of the doors after pulling the seal off and cleaning up the rough excess epoxy. This method allowed a nice holding edge to be formed for the seal so hopefully it won’t slip off later.
