GAYLON'S WEB SITE
Date:  12-15-2012
Number of Hours:  1.00
Manual Reference:  Section 38
Brief Description:  Section 38, Rudder Pedal after Market Brake Lines
I purchased the Bonaco brake lines for the after market Control Approach system. The Bonaco lines fit well and function with the movement of the pedals well. Spent 1 hour fitting them on December 15th.
QTY 2: -3 Hose assy w/clear at 37” OVL -3 straight to -3 straight @ $ 20.95 ea
QTY 3: -3 Hose assy w/clear at 12” OVL -3 straight to -3 straight @ $16.56
QTY 1: -3 Hose assy w/clear at 12” OVL -3 straight to -3 90 degree @ $22.50
QTY 2: -3 Hose assy w/clear at 31.5” OVL -3 (with -4 Nuts each end) straight to -3 straight. This is for the gear legs from belly to caliper. @ $28.50 each
QTY 1: 826-3D, for replacing stock plastic “T” @ $7.70
QTY 8: 822-3D, 1/8 NPT to -3 male 90 @ $5.00 $40
