I attached the MotoPod HardPoint attachment into the Mid Fuselage Ribs and Bottom Skin section. The instruction provided are straight forward and very well drawn with well made parts. Other than the fact you are working in a small space the install is easy. David did a great job at capturing all the required information and parts needed. I will install the forward HardPoint in an upcoming section. I did not make the seat pan access hole yet but will when I come to the appropriate section. More pictures once the entire aft attach point is riveted in. (7 hours)
