Brief Description: Wing Tip mounting and wire stuff
The wing tips are coming along nicely, I have them fitted and have been working on shortening the aft portion of the wingtip since the extended 3/8 inch beyond the rest of the wing. When I mounted the W-1016-L/R I should have paid closer attention to the racking going on in the wing tip. This caused the aft end of the wing tip to be offset slightly from the aileron and so I had to build up or remove material to make the transitions flow better. Lesson learned.
