Friday 23rd, started working on mounting the wing tips to the wings. Process was straight forward once the wing tips were marked up from trimming. A couple small trimming adjustments and the wing tips fit nicely. Drilled the mounting holes and machine dimpled them to except #6 screw along with dimpling the wing skins. The trailing edge of the wings tips are approximately 3/8″ to long. I have trimmed off the extra and am now adding fiberglass structure back to the wing tips since the joint at the end of the wing tip needs to be rebuilt.
The lights and lens was already mounted to the wingtip last christmas so they will be finished once the fiberglass work is done. I will also start working on mounting wire connections for the wing tips very soon.
