Brief Description: Flute Wing Spars, cutting and fitting W 1010-R/L
I started by viewing all the Wing Spars (W1010, W1011, W1012 - L/R) to see what ones needed to be fluted. Only one wing spare needed the entire ribs reworked. All other just needed the aft section of the rib fluted to lay flat. Step 6, I worked on mostly trying to get everything to properly fit including the W-1029D/E spacer and then I realized i was not supposed to be using the spacers while drilling the W-1029C angle. I was having difficulty with getting the W-1029A-L/B-L to cleco into the web of the W-1010R rib. I am guessing it will take more messaging before it will properly fit. I will continue this more Monday evening.
Continued to work with the W1029 brackets and with a little time I was able to make them fit properly.
