Started the morning very early, baby shower planned for 15:30 so we wanted to put some time in on the building. My Father worked most of the day and I worked maybe 3/4 of the time with bouncing back and forth between the baby shower and building (as the wife allowed). Finished up with Section 13-5, installing the tie down attach point and had an issue with one of the nut plates that stripped out. Since the nut plate is attached to W-1020 before being attached to the Right spar we had to cut the bolt and a portion of the nut plate off. We then attached a nut and epoxied it into place. I have pictures of this but not online. The fix looks good and function normal so I don’t see any issues with the change. The other two options were to remove all the rivet from the spare and risk messing up the holes in the spar or drilling one new hole thru the Right wing spar to attach a new nut plate. I didn’t want to drill a new hole thru the spar so I settled with the locking nut and epoxy solution.
