GAYLON'S WEB SITE
Date:  12-18-2010
Number of Hours:  8.00
Brief Description:  Vertical Stab Camera
I decided to mount a camera in the vertical stabilizer. I purchased a PC221.HR High Res Super Wide Angle Color Camera from SuperCircuits. Interestingly enough the camera had to be mounted at a slight angle. I am not sure if the was because the camera IC is not "true" to the axel of the camera case or not. Regardless the install work out fine and I think it will be a great enhancement to the plane.
