Picture 1 shows the coolant overflow bottle in place.
Picture 2 shows the oil tank in front of the right-hand carburettor. When I get the bits from Skydrive, I'll have to replace the pipe with the black plastic cover coming out of the carb. I may have to remove the oil tank.
Picture 3 shows the tube from the air balance tube to the sensor on the firewall. It doen't need retaining clips as it is a vacuum tube so should stay "sucked on".
