Finally I could remove the bolts retaining the two workbenches end-to-end and drill and bolt the tables side-by-side to build the fuselage. The casters on the two inboard legs now interfere with each other, a design shortcoming that I had not considered. I may have to saw off the brake flaps on these wheels so that they can rotate freely.
You can see that the Centre Section Bulkhead has finally seen the light of day, Picture 1 The dust on the top shows how long it has been lying around awaiting attention.
