First up is to rivet the fragile Tip Attach angles to the outboard end of the spars. Picture 1.
At the other (fuselage) end of the spar the hinge assembly and the doubler go on. All pop rivets. Notice gaps where ribs will also be attached. Pictures 2 and 3.
