Finished off Page 06-04 Step 3, which is countersinking VS-1203. This time I spent more time adjusting the countersink to the correct depth. Anticlockwise on the top barrel raises the drill bit. Each tooth makes a miniscule difference. Noted Jerry Greenberg's earlier comment about tightening up the top to prevent the setting “jumping”. It works loose rather easily.
28/02/09 Note Page 06-04 Revision 1 which includes an additional step to final drill some holes in VS-1202.
