Brief Description: Installing an Adel Clamp above the Fuel Flow Unit
The work for this step depends on which Fuel Flow Transducer is installed. Mine is a Flo-Scan. This requires removal of one of the original bolts, and replacement with a longer one, with a spacer and another Adel Clamp on the top. I wish I had known not to tighten the bolt originally. It was easy to tighten at the time, but harder to undo with structure all around it.
Picture 1 shows the clamp in place. The wiring partially obscures the adel clamp and the longer bolt. The fuselage is still on its side.
