Greg's RV-9A Builder Site
Date: 5-23-2009
Number of Hours: 3.00
Brief Description: Engine wiring, throttle quad, flap pos. sensor
Started out by installing the control cable firewall penetration seals, by removing the cables from the engine, and brackets, and then sliding the round nut that holds the two halves of the ball together, that clamp on the cable, and provide a firewall seal. When the quadrant is actally bolted in position, and I see that the cables are where they are going to stay, I'll cover those with some sort of fire resistant goop, like red RTV. Then I put a few clamps holding the ignition wires, and a few more zip ties to tidy up the wiring in the engine compartment. Last, I fabricated a small tab that gets held by an adel clamp, mounted to the flap tube, and messed around with its placement so that the flap position sensor could get from almost stop to stop. Tightened that down, then drilled holes and attached the flap position sensor. Still have to wire that up, next time. Then Jack invited me to go swimming, so I did.
