This is a couple of days work combined, attempting to close the gap in the cowling, where I cut off a bit too much on the back end. Epoxied a strip of glas around the edge of the top and sides of the cowl, let that cure, cut it back a bit, and then put the cowl on to fit. Traced the line of the forward fuselage, and trimmed again. Re fit and re drew the line to final cut, which I'll do after filling the layer of glass with epoxy and micro to bring it up level with the rest of the cowl. I sure hate fiberglass, but it is awfully forgiving of my mistakes.
