Installed upholstery on the center console and reinstalled the fuel valve control, and the throttle quadrant. Then I attached the arm rest/map box cover with a hinge. Looks pretty good. Then I started in on the LED Nav Lights. Started fitting the right one by first fitting the strobe back mirror, and then the LED. The LED has a countersink that must have a square hole cut for it, and that was a little tricky. Mosty trial and error until it fit right. Still off just a little to get the screws in, but I was tired of making and breathing fiberglass dust. I'll finish those up tomorrow I imagine. Briefly plugged in the right nav light to the battery, and it was BRIGHT. As advertised.
